Bug-Report: Reliable crashes in lap list
Alex
Post by Alex »
The Laptimer (pro) crashes every time, when i push the Edit-Button in the Lap List. Currently there are only 2 laps in my list, "unspecified" and "private". As far as i remember, the problem appeared after deleting some laps. But now the crash is reproducible every time, when i am pushing the Edit-button.
Regards,
Alex
My config:
- IPhone 4, 16 GB, latest firmware
Re: Bug-Report: Reliable crashes in lap list
The POI List / Lap List integration was not as smooth as I thought... The bug is fixed already, the fix will be part of 13.3
You may work around using the Edit button currently. To delete a POI Set, press the gray (first) row of the track set and purge the POIs afterwards.
To add a track set, simply go to the Add-ons View and download whatever track you need.
In case you need to run another combination, please let me know and I can check for another work around.
Sorry for any inconvenience.
