Scenarios of adding/recording Video
Posted: Tue Jun 25, 2019 4:13 am
I'm new to Laptimer. I played the video overlay for days but still very confused about how it works. Here's are scenarios below. Please confirm if these work or not. My tests were done by Race -> Classic with single video clip every time.
iOS - iPhoneX
Laptimer - latest version
- Should the video clip as same length as the collected metrics?
- To start GoPro recording manually instead of triggered by the laptimer. Then adding the video afterward to the lap. The video is longer than the lap time. Does this work? If so, how to sync the video with overlay data?
- To start GoPro recording manually instead of triggered by the laptimer. Then adding the video afterward to the lap. The video is shorter than the lap time. Does this work?If so, how to sync the video with overlay data?
- To trigger the GoPro via laptimer. The video is about 0.5s delay than the overlay data. Should I change the video delay from expert setting or set the end of timed lap from Video Sync Setting view?
- To trigger the GoPro via laptimer. The video is about 0.5s ahead than the overlay data. Should I change the video delay from expert setting or set the end of timed lap from Video Sync Setting view?
iOS - iPhoneX
