1/2 mile drag race
mecheng1
1/2 mile drag race
Post by mecheng1 »
wannaGOFAST.com is running their 1/2 mile drag race at Jumbolair in Ocala Florida April 13, 14.
Just wondering which is best to use. Timer or speedo on my Laptimer. Obviously I want video capability and max speed at 1/2 mile.
These are great events by the way !
Re: 1/2 mile drag race
You need to set up the “track” as custom track using the AX assistant or by setting triggers using the Map View. Please see www.gps-laptimer.de/documentation for the document on Trigger Logic and the older tutorial on setting up tracks. In case you can use the assistant, it is much easier.
mecheng1
Post by mecheng1 »
Ran several, 14 passes, I have videos but cannot overlay, get error 16 message.? Cannot export.
Android? Try the Force Software Encoding setting in Administration / Settings / Expert Settings.
