Laps are only recorded when I use video.
When not, nothing is recorded.
Laps not recorded
Re: Laps not recorded
No, this will be some coincidence with a different problem. LapTimer production versions are regression tested without video before being released. It is possible detection doesn't trigger because of missing / bad GPS or missing track sets, or some other reason, but video is always an add-on.
NB: Recent LapTimer versions 22.1.x did not trigger laps for s/f lines going N/S or W/E plus some other rare scenarios. This issues will (hopefully) be fixed with 22.1.2. The current 22.1.1 should work a lot better than 22.1.0 already.
In case you are sure you used 22.1.1, please let me know which track set you used when running into the problem described.
I am using v22.1.2.
It happend at Clastres and Abbeville. Only the laps where I use video are recorded.
Just to clarify: you are using 22.1.2 now. As it has been released yesterday (Android), you will have used 21.1.0 or 21.1.1 for the date reported initially.
Now it works perfect.
