Kiwi 3 + Alfa : Low OBD connection
Jeremiev
Post by Jeremiev »
Hi
I am the owner of an Alfa 4c. I installed a kiwi 3 but despite all tests, the connection speed is very slow. below the screenshot of the sensor speeds
Re: Kiwi 3 + Alfa : Low OBD connection
You are receiving 37 PIDs/s which results in an overall update rate of 10 Hz. This is actually a good value - you can't achieve a lot more with an ELM based Bluetooth Low Energy sensors (available bandwidth). You can optimize results by switching from ALL control units to just ECM/PCM. Enter "PCM" into the respective Expert Settings field.
Jeremiev
Post by Jeremiev »
thanks for the answer, but what's the difference between a PCM and ECM setting
This are simply to common abbreviations for the main engine control unit. Both have the same effect independent from car or configuration.
Jeremiev
Post by Jeremiev »
