Where are data ?
dydy77
Where are data ?
Post by dydy77 »
My friend have a probleme.
Last wenesday we was at Dijon-Prenois track in france.
He use iphne 6 with ios 11.4.1.
He recordiing all the day with internal sensor.
All seems to be good, but he can't acces to data.
There is no map track in lap result.
He export to me .hlptrz best lap and all lap.
When i import best lap is ok, but no data, no track map on my android too...
And i cant importe all lap, i have an error of import.
Look this picture, and his export.
It is like time was present, but not the data....
Can you look what is the problem ?
LapTimer-0072-20180910-145654.hlptrz
(502 Bytes) Downloaded 393 times
LapTimer-0053-0098-20180910-153942.hlptrz
(2.07 KiB) Downloaded 343 times
dydy77
Re: Where are data ?
Post by dydy77 »
dydy77
Post by dydy77 »
dydy77
Post by dydy77 »
Here is my lap recording on this day (android + 10hz), i can acces to lap detail, map track etc....
There are two relevant entities stored in LapTimer per lap: one lap record and multiple position records documenting the positions etc. driven. The later is missing for the laps shown. This can happen in case you run into memory shortage or unexpected conditions (crashes etc). In most situations LapTimer will create an automatic backup before removing position data. Please check Administration ‣ Databases and look for the oldest backup with the full number of laps. Swipe this entry (long press in Android) and try the Restore function. In case it works and you are able to run Check Data afterwards, your database is fine again. In case this doesn't work, you need to check the next older backup available.
dydy77
Post by dydy77 »
You are the best !!!
He restored the first backup after the track day, and all is good !
Data are present, and perfect.
Thanks U
Please do not forget to run Check data. You may need to run it several times, but it should report the database is error free finally.
dydy77
Post by dydy77 »
Yes it is done.
Thanks U
