Nordschleife Full Lap and BTG analysis
Posted: Sat Jul 21, 2018 2:03 pm
by NOS M3F80
I have been using HLT GRand Prix Edition on the Nordschleife. I can use either Nodschleife Full Circuit or BTG. However when I am driving several rounds in a row I sometimes would like to analyse my BTG and my full circuit times retrospectively. Is this somehow possibe? So that I would use the Nordschleife Full Circuit to drive and later on check the BTG times?
Thanks for your help!
Re: Nordschleife Full Lap and BTG analysis
Posted: Mon Jul 23, 2018 10:17 am
What you can do is exporting your full lap recordings to either GPX or VBO and reimport this files with the BTG track set loaded and the Full Circuit track set unloaded. This will create new laps from the input. Use the export function for GPX/VBO and send the mail to yourself. Once it arrives, select the attachment from the mail and select LapTimer to open it.
Posted: Mon Jul 23, 2018 8:42 pm
by NOS M3F80
thanks a lot. I will try that the next time I am on the NOS.
Will I also be able to overlay videos on the BTG data then? I guess that will only work If I cut them beforehand accordingly?
Posted: Wed Jul 25, 2018 3:25 pm
You probably need to realign data and video. But try it, it may work without further fiddling. As long as the video is a continuous full session video, you will be able to use it for BTG splits too. No need for cutting, LapTimer extracts the portion required when overlaying videos.
