PLX Kiwi 4
Re: PLX Kiwi 4
Post by Harry » Wed Jun 26, 2019 7:37 pm
Please have a look into the Train the Trainer document available on www.gps-laptimer.de/documentation. In case you have a GrandPrix edition, you can use the bottom diagram to set two cursors. This will allow you to analyze a certain section.
krell
Re: PLX Kiwi 4
Post by krell » Wed Jun 26, 2019 9:27 pm
I looked at that but didn't find it intuitive or helpful so I guess I'll keep working on it.
Squared
Re: PLX Kiwi 4
Post by Squared » Sun Mar 29, 2020 7:39 am
I’m looking to buy a kiwi 3 or 4 to use with your lap timer in my 2000 Audi TT MK.1.
I like the kiwi because I will have both wi-fi and BT options, giving me better scope to connect other peripherals to my phone (such as a camera or external BT).
It’s no clear whether or not the kiwi is compatible with this older vehicle. The TT runs CAN bus and has an OBD II port.
Could you please let me know if the Kiwi will work in this old car. If not, what OBD II device would you recommend?
Thanks Dave
Re: PLX Kiwi 4
Post by Harry » Sun Mar 29, 2020 6:25 pm
I can't answer questions on adapter / car compatibility except for my own car. :-) Please contact PLX in case you want to be sure front up. To my understanding, your TT came with a first CAN implementation which has been improved later. This may cause trouble, but it may work too.
