HLT doesn't see Dual XGPS
zmaniac
Post by zmaniac »
I am running HLT 21.2 Petrolhead on iPhone 4S. After hearing that issues with Dual GPS devices had been remedied with latest firmware upgrade, I updated the firmware on the Dual GPS. But HLT doesn't recognize that the Dual GPS is connected by bluetooth. It shows it being connected in the iPhone bluetooth settings, and the blue bluetooth light is lit on the GPS unit. Tried restarting HLT, iPhone, Dual unit to no avail. This is discouraging since I want to use the superior video capture I used to get on the iPhone 4S before I bought a iPhone 7. But I need the 10 Hz position data the Dual used to provide. Please help. Thanks.
Re: HLT doesn't see Dual XGPS
Sounds like some configuration issue. Please check if you have disabled Accessories in Expert Settings accidentally. Furthermore, make sure you do not have apps accessing it in background (i.e. kill others).
zmaniac
Post by zmaniac »
It works! Thanks! Somehow, accessories in Expert Settings was set to OFF.
