Connectivity with RaceCapture/Track & Garmin Virb Ultra 30
akebal
Post by akebal »
Already own Grand Prix HLT on android and Garmin Virb Ultra 30. Will HLT work with intended accessories of RaceCapture/Track, as GPS and OBD, and Garmin Virb Ultra 30 as a camera ?
Probable connection configuration :
- Grand Prix HLT on Andriod with client wifi
- RaceCature/Track, wired OBD, with client wifi
- Garmin Virb Ultra 30 with AP wifi
Re: Connectivity with RaceCapture/Track & Garmin Virb Ultra 30
You can't connect your smartphone to more than one WiFi at a time. So while RC is connected, you need to operate your Garmin manually. Footage recorded can be added to LapTimer manually later. See Video Documentation for the details.
akebal
Post by akebal »
Wonder if both the android smart phone (with HLT running on) and RaceCapture/Track connect (as wifi clients) to the same Garmin Virb Camera Wifi Access Point, could HLT running on the android smart phone, somehow knowing RaceCapture/Track's ip address, communicate with the RaceCapture/Track ?
LapTimer works with all RCP devices. RCPs can be customized a lot, please have a look into the RCP FAQ here in the forum to understand what LapTimer expects as input. You can connect to a sensor or cam from two apps / devices at a time. These are always so called exclusive resources.
akebal
Post by akebal »
Thanks for your response. I think you refered to this "[HOW-TO] RaceCapture Device Configuration" @ viewtopic.php?f=6&t=4789. This actually led me to acquire a RC/Pro MK3 instead of RC/Track in order to be able to utilise BT conectivity while leaving Wifi connectivity available for camera.
