Data in overlay frozen when viewing video
tarmactrr
Post by tarmactrr »
I've tried searching and can't find an answer, but hopefully this is simple.
I have a video which when viewing the data recording, all data shows up, but when trying to export the video with the overlay, the overlay timer runs, but nothing else functions. The G meter and speed just sit motionless for the entire run. How do I correct this to get the overlay to work properly? It was working properly when I was recording the video.
Re: Data in overlay frozen when viewing video
This usually means you had no or bad GPS reception. While LapTimer shows data (acceleration, GPS, OBD) while driving as it is coming in, it stores data using the GPS drum beat. In case your GPS is weak or didn't work, you see acceleration and OBD while driving, but not in the overlay. To verify, please have a look into the lap's data recordings. Do you see reasonable data in Lap Details ‣ Data Recordings ‣ Charts?
tarmactrr
Post by tarmactrr »
I believe the data in the lap details is good.. See below
That look ok to you or do I have a bad gps issue?
Your photo hosting does not work ;-)
