Track Map in wrong spot
llan981
Post by llan981 »
Did a few overlays and the track map for Watkins Glen rendered in is a very odd spot. Any thoughts?
Take a look:
https://youtu.be/43cuuMbj3Y4
Re: Track Map in wrong spot
Not sure I understand what "odd spot" means. Please note that LapTimer v21 is coming with a changed default overlay for the position on the map. "Dynamic Map" shows a rotating and speed controlled zoomed map instead of the standard map. You can change back in Export / Overlay Configuration.
llan981
Post by llan981 »
I meant to say, I am so use to the fixed map that the dynamic map was new to me.
