Larger gear ratio's
rough68fish
Larger gear ratio's
Post by rough68fish »
I have an 05 Mini Cooper S if you look here http://www.motoringfile.com/files/MINI_2005_specs.pdf it has two different final drive ratios depending on the gear. So I am struggling with entering the ration. It would be easier if I could set the final drive to 1.0 and enter the calculated final drive but for first gear that is 12.789.
Re: Larger gear ratio's
Here is the FAQ: viewtopic.php?f=39&t=3425
planetshg
Post by planetshg »
You're writing that you already processed your variable final drive into your resulting gear ratios.
If those are too large for HLT using a final drive ratio of 1.0, you could recalculate your gears for a higher final drive ratio, like 2.0 or 3.0 and include that as well into HLT.
