Bug report: External cam control and video export
Posted: Sun May 28, 2017 3:47 am
This is on android and using sony cam, so I can't say if it affects iOS or gopro.
External cam start/stop over wifi works when I have internal cam + external cam set up to record from the Timer screen. If I select external cam only (which is what i tried to use the other day), the wifi start/stop does not work. I repeated the test a few times back and forth with app reboots etc, and it was repeatable so I think it's legit.
Also this one isn't a huge deal, but when exporting a video under "video details" to Google Drive, it gives the file a generic name with no extension, it doesn't seem to copy over the file name or extension type. When exporting to gmail or some other apps, it appears to work fine, but I was hoping to get it working with drive, since that I what I use to upload big video files to send to myself/transfer over. I can make it work by manually naming each file and adding .mp4....so not a big deal, but figured I would let you know.
