PIP timing vs phone video timing
Posted: Tue May 09, 2017 12:49 pm
by MrBlah
is there any way to adjust the PIP timing without changing the phone video timing?
I've got my phone timing matched up with the mk2 data perfectly now, but the gopro timing is off. If I swap master and PIP I can adjust the timing again but then the PIP phone camera is off.
Am I not seeing a setting to adjust them separately ? I've been known to miss settings before
Re: PIP timing vs phone video timing
Posted: Tue May 09, 2017 3:48 pm
by gplracerx
You should be able to adjust the sync points separately. IIRC, it's down near the bottom of the video data screen.
Posted: Tue May 09, 2017 4:52 pm
by MrBlah
yeah, very painful on each vid, I've never successfully used that sync point edit to fix it, given up on that. they are always off by the same amount if it was a setting it would make it easy
