Hi
New to Harry's lap timer. When trying to set up my motorbike in 'my vehicle' section i select motorbike with no other options selected and even at that point the message at the bottom of the screen says 'no matches to my criteria' therefore i can't continue to select my motorbike.
What am i doing wrong and how to i select my motorbike from this list??
No motorbikes available
Re: No motorbikes available
Nothing wrong, the number of motorbikes submitted to us is simply a lot smaller and Monika - who is working on the vehicle QA - has skipped motorbikes until all car submissions are done. To continue, just enter free text into the fields and press New once you are finished.
kawasaurex
- Fewer than 10 Posts
I can submit/post my Kawasaki motorcycle info if it helps to add to the database.
Yes, please submit it. We are still behind with QA-ing submissions, I'm sorry.
kawasaurex
Thank you Harry. It's a 2008 Kawasaki Concours 1400. I've emailed you the file since I'm not sure how to attach it here.
Thanks for sending your bike. Please consider sending it using the certification function (somewhere in Vehicle Details). It will do some front up analysis on completeness and will feed the definition right into the QA queue we are working on.
Thanks again, Harry
Thanks again, Harry
