update rate for cheap chinese OBD wifi
doborder
Post by doborder »
Does any one know if there is a big difference between Kiwi Wifi and the cheap chinese version on ebay in terms of update rate?
I only have the cheap chinese version and I can only get up to 3hz on my 2010 Nissan GTR.
Any feed back would be appreciated?
lorenzino
Re: update rate for cheap chinese OBD wifi
Post by lorenzino »
what's the cheap knockoff?
this one?
http://www.amazon.co.uk/WIFI-OBD2-Scann ... 838&sr=8-3
I'm also looking for a way to get some obd readings on the cheap.
doborder
Post by doborder »
Yeah, that is the one I got
I'm not sure if the update rate is lower due to the device or If kiwi wifi will be slow as well
hms
Post by hms »
Isn't the update rate dependant on the cars OBDII bus?
Hence the varying speeds for different cars.
See:
viewtopic.php?f=20&t=26
Regards
Howard
The bus is the main component. However, there are differences between the OBD dongles too. I tested the Kiwi on a 911 with 7.0 Hz, OBDLink did between 10-11Hz... Probably not representative, but an observation.
