How to delay gopro overlaid video
Posted: Sun Sep 25, 2016 2:26 pm
by born2boost
Hi guys...
I have managed to overlay my gopro video on to my lap but it's abit faster than the actual video and gps.
How do I delay it?
I've. Looked.around expert settings but can't seem to figure it out.
Please help
Re: How to delay gopro overlaid video
Posted: Sun Sep 25, 2016 2:36 pm
Please search the forum for "sensor delay". Usually it is fine to adjust the Overlay Synchronization / Video Expert Setting. In case you have added the GoPro video manually (I.e. using Add Video), the sync point has not been set correctly. Do not use the named delay in this case but adjust the sync point from Video List / the video / Lap sync.
Posted: Sun Sep 25, 2016 3:10 pm
by gplracerx
I don't see a Lap Sync line in the video in the Video List. If I set the finish frame after I relink the video or add a new video, then the only way to sync the video and the data is to set the Video Delay in Expert Settings to zero.
Posted: Sun Sep 25, 2016 3:45 pm
The row is labeled "Lap #xy" with a value like "ends at xx:xx:xx" in the "LapTimer Integration" sections. Touching this row will bring up the Video Synchronization dialog allowing an individual adjustment.
