Page 1 of 3
Online Question
Posted: Sun Sep 18, 2016 10:00 pm
by dydy77
Hi Harry's,
This week-end i was on Dijon (france) track day !
I used my old android phone for HLT, without SIM card, so no data transfert to online server.
So my lap-timing not appeared in online HALL OF FAME.
I would like to know if i can send my data to the hall of frame after (now for exemple) ?
What is the difference between this 3 options :
HLT -> Reglage (settings) -> Course Live (Live Race) -> transmettre (sending) -> Jamais (Never)
HLT -> Reglage (settings) -> Course Live (Live Race) -> transmettre (sending) -> Chronometrage (Lap timming)
HLT -> Reglage (settings) -> Course Live (Live Race) -> transmettre (sending) -> Permanence (always)
Do you have new about your development on hall of frame (online) options, as the full name of driver, more filter etc....
Re: Online Question
Posted: Mon Sep 19, 2016 10:40 am
For the three Online Racing settings, please have a look into http://www.gps-laptimer.de/privacy-policy section "LapTimer Server".
You can submit laps recorded with an certified track set after the fact. Select the lap from Lap List and use the Hall of Fame button to send the lap to the server. NB: duplicate checks are limited, sending it once is enough. ;-)
Re: Online Question
Posted: Tue Sep 20, 2016 8:00 pm
by dydy77
Ok thanks,
I have moved setting Publishing to : Lapping (default).
I tried to send my lap after fact,
For that, I click on my Best Lap, it is opening it, after i click on Hall Of Frame menu setting button.
A message says : Lap would be transmit to the hall of frame
But nothing appeared on the table. Have you an idea ?
Re: Online Question
Posted: Tue Sep 20, 2016 8:02 pm
Please check if a filter is set for the list, e.g. only named drivers or only if +/-5% matching the standard distance.
Re: Online Question
Posted: Tue Sep 20, 2016 9:29 pm
by dydy77
Ok thanks, problème is +/-5% filter.
But i dont understand why ? All my lap are around 3630 3650 m
The filter is +/-5% of 3800 ! Officially the track length is 3800 OK
-5% of 3800 is 3610 all my lap are longer than this lenght :(
Re: Online Question
Posted: Tue Sep 20, 2016 9:45 pm
Please post your driver id, vehicle name and time and I will check if it has arrived or what's wrong with it.
Re: Online Question
Posted: Tue Sep 20, 2016 10:07 pm
by dydy77
Driver ID : DYD
Vehicle : 306 TCT
Lap : 1.54.79 // 1.42.43 // 1.42.82 // 1.45.69 // 2.11.30 // 1.42.52 // 1.42.16 // 1.43.74 // 1.55.28 // 1.40.28 (best) // 1.45.01
Re: Online Question
Posted: Fri Sep 23, 2016 10:17 pm
by stevevetter
I'm having a related issue. I have a Nexus 5x running Android 6 with no SIM. I would like to upload my laps after the fact via wi-fi. I go to online, pick list of drivers and try to do what you say; pick lap and hall of fame button. There doesn't seem to be a way to 'pick a lap' though. I touch once and get nothing. Long press, nothing. No radio button.
And I don't see a 'hall of fame' button unless you mean the header bar across the top.
Re: Online Question
Posted: Sat Sep 24, 2016 8:46 am
To submit a lap "after the fact", select this lap from Lap List. Now, in the Lap Details view, select the Hall of Fame button (iOS) or the Hall of fame function from the options menu (Android). In case the function is not available, the lap selected has not been recorded using a certified track set.
Re: Online Question
Posted: Sat Sep 24, 2016 12:00 pm
by dydy77
Have you look at track's lenght problem Harry ?
