Alternating tyre dimensions - how to handle?
A_Möller
Post by A_Möller »
I sometimes use my road tyres and sometimes my race tyres when running the HLT. The difference in circumference of the driving wheel tyres is not negligble. Do I change the dimensions in settings each time and it gets correct, or how do I make sure the right vehicle data is connected to each set of data logging?
Re: Alternating tyre dimensions - how to handle?
Setup your vehicle with one set of tires. Use the Duplicate Vehicle function in Vehicle Details to create a copy. Change the name and the tires spec here. Now, switch the current vehicle whenever you switch tires. For existing laps, you can change the vehicle associated by touching the respective row in Lap Details.
