Brake force
Posted: Fri Jan 13, 2012 12:04 am
by orthojoe
Is there a way to display brake force based on longitudinal G's from the accelerometer? I would like to be able display braking force on my trackvision exports
Re: Brake force
Posted: Fri Jan 13, 2012 12:07 am
Yes, thats possible and can be done using the TrackVision export provided by LapTimer.
Re: Brake force
Posted: Fri Jan 13, 2012 12:35 am
by orthojoe
Can this be done currently, or is this a feature that may be included in the future? If it can be done currently, could you explain how? Thanks.
Re: Brake force
Posted: Fri Jan 13, 2012 7:01 am
For explanations on TrackVision, please contact them. The LapTimer export for TrackVision and DashWare include a column named LINEALG. Negative values denote braking here. You need to transform this value and map it to the respective gadget in TrackVision. This transformation & mapping is done within TrackVision.
Re: Brake force
Posted: Fri Jan 13, 2012 7:20 am
by orthojoe
Got it. Thanks, Harry!
