Trigger location consistency with XGPS160
dbbarron
Post by dbbarron »
My first HLT use day at AX yesterday. After reviewing the video in detail, accuracy of triggers (start and finish line points) appears to be +/-.25s for the start line and +/-1s for the finish line yielding a timing accuracy of +/-1.25s for each run. This appears to correlate to the timing of the official system for almost every run with one exception where I guess there could have been some mis-trigger of the lights.
However, at AX, if I'm going to use HLT for fine analysis, +/-1.25s is not nearly good enough for viewing run to run differences. How can I improve things?
For every run I appears to have logged 10 fixes per second, but environment was 'Warning' due to magnetic conditions. The accuracy graph looks to be very good - small circles.
Thoughts appreciated.
db
Re: Trigger location consistency with XGPS160
The environmental warnings will generate a GPS drift. This means there is a certain offset between real position and measured position beyond the reported accuracy. As long as trigger definitions and actually driving within a short time frame, that's no problem. This shift changes over time. So in case you have an hour or more in-between, your recorded with be shifted and measurements can get wrong. The named timing accuracy is probably due to some other issue. For a 10 Hz device showing good accuracy, timing will be within 0.05s mostly. A bigger difference means the position used for start and stop are different to the positions the official system measured.
Be sure the XGPS160 has acquired lots of satellites before setting the POI's. In GPS view, there's a progress bar near the top of the page with the number of satellites acquired below it. Wait until the indicator is all the way to the right. It takes a few minutes after the XGPS160 gets its initial fix, i.e. the led stops blinking.
dbbarron
Post by dbbarron »
I have done further analysis and now realized a big mistake in my original methodology. I was using the video immediately viewable within HLT as my reference and assuming constant offset from start and stop triggers - this was a mistake.
I have now overlaid and exported 5 laps with good data from the afternoon.
First, I compared clock time to pass the first clear visual reference after the start. This is just over 2 seconds in, but is SPEED DEPENDANT, so some variation is likely.
Lap, Time to First Marker
1 2.31
2 2.52
3 2.28
4 2.64
5 2.38
Given likely variations in speed and limited frame to frame resolution, I'd say there was likely very little deviation from a constant starting point.
Finish times gives a better opportunity as they are not dependant on speed but on on errors introduced by a start point offset. For this test I logged the difference between finish time and time passing a visual marker near the finish (I have no way to know exactly where the HLT GPS finish is on the video):
Lap,Finish Time,Finish Marker,Delta
1 69.30 69.27 -0.03
2 66.45 66.39 -0.06
3 65.85 65.81 -0.04
4 65.04 65.00 -0.04
5 64.28 64.24 -0.04
So if we assume that the finish marker is 0.04s at speed away from the finish trigger there is only +/-0.02s variation and that includes variation introduced at the start trigger. I'd say that is impressive!
I hope to have official times soon and that will also indeed be interesting!
db
