Slow inconsistent update rates with Automatic + BMW 128i
Posted: Wed Aug 31, 2016 3:26 am
I've been using HLT for autocross and track days and I tried buying the automatic OBD dongle in hopes to get my throttle and RPM data. However, over the past couple months, I can't seem to get reliable stream of data. The data always seems very choppy. If I look at the engine details in laptimer app, I usually see an update rate of 0.5hz - 3hz so it is getting data but the rate is inconsistent which I believe is what's causing choppy data. An example of what I'm talking about can be seen here: https://youtu.be/ZcjoG8-PZPU?t=28s The throttle data and the RPM jumps about.
Reading the forums, it seems like other people are having issues with Automatic + Laptimer app. Is this just a limitation of the hardware and is this the best I should expect with my setup? If so, is there another OBD dongle that has so far been proven more reliable?
My setup is: iPhone 6 + XGPS 160A + Automatic + GoPro 4 (connected through Wifi)
