Better Calculated Acceleration Smoothing Setting
Posted: Tue Aug 30, 2016 12:04 am
I find that the smoothing I need is near the far right of the scale and the adjustment is way too fiddly for my fat fingers. Plus and minus buttons or some other form of fine adjustment that doesn't change when you take your finger off the screen would help a lot.
I've thought of a possible way to do this automatically by comparing the integrated yaw rate, derived from the speed and lateral acceleration, to the GPS heading and adjusting the smoothing for best fit. I would try it, but I can't reliably set different smoothing levels in the range of interest.
