Lap shows car image but no obd logging
MrBlah
Post by MrBlah »
am I doing somehting wrong? 2nd ax where I got no obdII data, using an obdlink MX bluetooth with android phone
Re: Lap shows car image but no obd logging
Looks like a dropped OBD connection, data shown has GPS and acceleration only.
Please have a look into the OBD Debugging FAQ here on the forum.
MrBlah
Post by MrBlah »
another day with no odb logging, 2 days actually it'll even show connected but nothing logs, I used the recommended ODBlink MX and it did not work at all, switched to generic elm327 and it looked like it would work but never did
Do you have the latest version installed? I recently made connection making more reliable. The problem has been that after turning the engine off without disconnecting / inactivating LapTimer and turning it on a some time later could lead to an OBD connection not delivering data.
MrBlah
Post by MrBlah »
That must be it we shut down between runs but I leave Laptimer running the whole time
The symptom have been very high update rates for OBD - because all PIDs between 0101 and 0110 have been skipped. The current version has this fixed.
