Automatic Start
Bobl36
Automatic Start
Post by Bobl36 »
This morning I was practicing with HLT for an event tomorrow. I must have reset something inadvertently, but the app is not working as before. I used the Autocross wizard to set start & finish. As I approached my mark I did not get the "stop & press stage" dialog box. I cleared the track set and tried again. I did get the stage button, but when I crossed the mark the display started with a negative number...-8.250 and counted down to zero then timing actually started.
Yesterday I had the no stage issue and have no idea what I did, or what I did to fix it this morning. But I am still not getting proper times with out the negative number after start.
Any Suggestions?
Bobl36
(I really hate being stupid!)
Re: Automatic Start
please clarify
"I did get the stage button...": is this after you had set up a new AX including a start and a finish?
"display started with a negative number...-8.250": which display? Are you in the AX assistant?
MrBlah
Re: Automatic Start
Post by MrBlah »
same with mine on android, I did not get stage button today but I did when I tested a few weeks ago
I ended up manual running it, and forgetting to hit stop :(
Re: Automatic Start
In case you can't find the staging area, open LapTimer ‣ Analysis ‣ Realtime ‣ Maps. This will show you position and the triggers around. It will help you to identify if the trigger is set at all, if GPS accuracy is good, and if the trigger is set in the correct spot.
