BT1 OBD and Roush Lap Timer
Slammer
Post by Slammer »
I recently purchased the GOPOINT Technology BT1 -
I have an IPAD with iOS 9.3.1 - I have aslo tried it on my IPhone 6+ with iOS 9.3.1
I have downloaded the BT1 APP and it connects just fine
I have also have a recently downloaded the latest v20.0.3 HLT
I have also used the HLT to log a race so it works fine....
The question I have is I cant get the BT1 to show up in the sensor selection?
I have made sure there are no other APPS accessing the OBD
I haven't played with any Expert Settings as of yet
Re: BT1 OBD and Roush Lap Timer
Although GoPoint has white listed the BT1 for ROUSH Lap Timer already, the current version has it not yet listed it and will not connect. I will add the accessory to version 20.0.8 or later - whichever comes first.
Slammer
Post by Slammer »
Ok - Thanks
speakerpower
Post by speakerpower »
Was this ever fixed? I was trying to use BT1 at the track this weekend. HLT said it had timed out immediately after starting. Had not been 10 minutes.
GoPoint support has been enabled in ROUSH LapTimer 20.0.8 as posted above. We are at 20.1.1 for iOS now. For your issue, please post what exactly you mean by "timed out immediately...".
speakerpower
OK I don't know what Roush Lap Timer is. I only have Petrolhead Laptimer. Do I need a different version to use BT1?
Ok, so this is off topic. Please start with having a look into the debugging OBD connections FAQ here on the thread. I do not have any BT1 issues on my list, so it is likely some configuration issue. When asking for more support, please post your full configuration.
