Page 1 of 3
update rates on bluetooth android/iphone compatible
Posted: Wed May 04, 2016 2:07 am
by MrBlah
anyone care to comment on update rates with the bluetooth android & iphone compatible adapters?
I'm using a xps160 gps so I would like to get a faster adapter to match, I'm running android now but I might switch to an ipod touch for simplicity and saving some of my already "mini" windshield view
Re: update rates on bluetooth android/iphone compatible
Posted: Wed May 04, 2016 8:33 am
In case you want an adapter working for both platforms, you need to use GoPoint's BT1A. It is not the fastest but a very convenient device (set and forget).
The best OBD adapter for Android is OBDLink's LX/MX Bluetooth. It is super fast and as easy to use as the GoPoint. But it is limited to Android only.
Rates to expect are 2 Hz (10 PIDs/s) for both for non CAN cars. For CAN cars, you will get 7 or 8 Hz for the GoPoint and up to 20 for the OBDLink.
More details and distributors are listed on
www.gps-laptimer.de/compatibility/android
www.gps-laptimer.de/compatibility/ios
Posted: Thu May 05, 2016 9:53 am
by PitrsRS
on car with CAN i have 12-15Hz update rate with OBDLink LX on android device. I think it´s enough for compare with XGPS160 (i have it too)
Posted: Thu May 05, 2016 2:10 pm
Yes, that's a perfect rate.
Posted: Sat May 07, 2016 1:12 am
by MrBlah
I picked up a OBDlink LX getting 2hz update rate.
I think I only care about rpm & throttle right now, is there a way to ask for only those PIDs to speed things up?
Posted: Sat May 07, 2016 10:07 am
MrBlah wrote:I picked up a OBDlink LX getting 2hz update rate.
This has been discussed here on the forum *often*. ;-)
Please check e.g. viewtopic.php?f=20&t=2246&p=11540#p11540
A 2 Hz update rate (i.e. 10 PIDs / s) is a typical rate for pre-CAN busses. Except wiring sensors directly (working around the car's bus) there little one can do. But please check the post above, it has it all.
Posted: Sat May 07, 2016 1:55 pm
by MrBlah
It's a 2005 mini r53 they have can bus
Posted: Sat May 07, 2016 6:20 pm
MrBlah wrote:It's a 2005 mini r53 they have can bus
Sure? I checked some lists and they say Minis started CAN in 2007.
In case you can verify it has a CAN bus, there is an issue with the OBD connection. It should be higher than 7Hz (probably a lot higher). Please check viewtopic.php?f=39&t=1500 in this case and send a log.
Posted: Mon May 09, 2016 2:53 pm
by MrBlah
Yeah should be k-line
Posted: Mon May 09, 2016 4:24 pm
K-line is not CAN.
