GPS sync needed ?
joeljacob
GPS sync needed ?
Post by joeljacob »
I'm new to Harry's laptimer (grand prix ed on android).
I was trying to create a track from a road. I succeeded, but the app insisted that I needed an active GPS to create a new track.
Is this normal or desired since you normally prepare a track at home where GPS connexion is not available ?
Thx,
Joel
Envoyé de mon SM-T810 en utilisant Tapatalk
Re: GPS sync needed ?
Yes, that's expected. The AX und New Track assistants are designed to set up new tracks on site. They use the current GPS position to set triggers. In case you want to define a track at home, please use the Map View to create triggers in specific positions. No GPS required here. A slightly outdated tutorial is available here: http://legacy.gps-laptimer.de/Tracks.html
