Problems with Overlay Snychronization
Posted: Tue Apr 12, 2016 8:46 am
Hey Harry,
bought myself an XGPS150 and a Gopoint BT1 in Winter which I now used when driving over the Nordschleife.
I use Harry's Laptimer Grand Prix Edition, starting screen says version v19.0.31(64) on my iPhone 5s (Version 9.2.1)
When tapping onto Overlay I come into Overlay Konfiguration Menu. I can choose between "Vorlauf" and "Nachlauf" (standard: 0s, 0s). (sorry for German description).
But the only adjustment I can do is to choose for "Nachlauf" (should be delay in English) between 0s and 1s. Which is the first thing I'd imagine is not normal.
When using standard setting (0s, 0s) the OBD-Data in Overlay Video is about 1,5seconds ahead in comparison to reality (sound, video).
So I have two questions:
1. How can I fix this issue, how can I create the overlay video with correct OBD synchronization? Found in expert settings a menu point called Overlay synchronization "Video (0.0-9.0s) which is set to 1 (i didn't change that).
2. For my next laps using the Laptimer: Should I change (in expert settings under menu Sensor Delays) the delay of "any OBD (0.0-3.0) from 1 to 2,5?
Thank you in advance for your help and best regards,
Jonathan
Jonathan
