Looking for second layout of Rockingham International
R4SC4L
Post by R4SC4L »
I'm going to Rockingham Motor Speedway circuit and it seems they now typically run the a layout called the International Super Sportscar Circuit (see blue line on the picture below), whereas the track set in the library for the lap timer app is the International Circuit.
Can you help me create a "Rockingham International Super Sportscar Circuit" please with the adjustments being the red line on the picture below?
Many thanks
Re: Looking for second layout of Rockingham International
We will add it as a new configuration and come back once it is available for download. Thanks for sending the sketch.
R4SC4L
Post by R4SC4L »
Many thanks - though having re-read my post I should clarify:
The blue line represents the current track layout in the Lap Timer library, known as Rockingham Motor Speedway International Circuit.
The amendments with the red lines represent the Rockingham International Super Sportscar Circuit, which is the layout I'm looking for.
Monika
Post by Monika »
the Rockingham Super Sportscar Circuit configuration is now available for download.
Please check it out via 'add-ons', update the list via the button at the top right corner and search e.g. for ‚Rock‘.
Regards,
Monika
