Deleting files
Gsyk59
Deleting files
Post by Gsyk59 »
Every time I try to delete individual laps, I get an error that says "laptimer has stopped working". Only way I can delete laps is if I select the "delete all" option.
Re: Deleting files
Does this happen both for deleting a lap in Lap List (long touch the lap and press the bin), and when navigating into the lap and deleting the lap from Lap Details? What is the lap index shown and how many laps do you have in your database?
Gsyk59
Re: Deleting files
Post by Gsyk59 »
Long touch seems to work. I was using a short touch and then selecting the delete function. I'll use this long touch method from now on.
Puma98
Re: Deleting files
Post by Puma98 »
I'm having trouble deleting files - iPhone 5. I have 76 laps. When I try to delete individual files or delete all the app just quits. The swipe method has the same result. In most cases the app asks me whether I want to delete the files and when I confirm it quits.
Re: Deleting files
Please run Check Data first. I assume there is some inconsistency crashing LapTimer when deleting all data.
Re: Deleting files
PS: Deleting all laps makes rarely sense. The data itself requires very small amounts of storage. In case you want to reduce memory footprint, start with deleting media files and old system backups. Both can be done in Administration - Databases.
