				[SOLVED] Two final drive ratios
				Posted: Mon Nov 14, 2011 10:39 pm
				by snowfree52
				One of my cars is a golf and it seems there are two differents drive ratios by gearbox :
one for 1, 2, 3 and 4th gear
a second for 5 et 6th
I wonder how is that possible and if there is a way to implement that in the laptimer ?
				Re: Two final drive ratios
				Posted: Mon Nov 14, 2011 11:25 pm
Frequent question. To map this, simply calculate the full ratio (drive + gear) for each gear and enter these value for the gear ratio. In addition, set the drive ratio to 1.
				Posted: Tue Nov 15, 2011 4:52 pm
				by snowfree52
				Thank you very much
Since I found the "how to" by myself :
formula is: (final drive ratio * gear ratio) /2
and put 2 as the final drive (because the app doesn't accept more than 10 as gear ratio
edit : I have a problem :
since I have a car with the max power at low RPM, the app gives me max speeds that are way too slow (for 6th speed there is a 45kmh difference)
				Posted: Thu Nov 17, 2011 9:07 pm
				by fluppie00
				I've driven a Audi S3 for a week, this car has also 2 drive ratios, I recalculated the drive ratios like this:
I've multiplied all the gear ratios with the final drive ratio and then the results from 5th and 6th I divided by 4.24.
Like this I calculated the 5th and 6th for a 4.24 final drive ( The 'real' final drive in 5th and 6th is 3.27 ). Should work fine !
				Posted: Thu Nov 17, 2011 9:50 pm
				snowfree52 wrote:edit : I have a problem :
HI again,
max is calculated for the rpm max power is developed. You need to read is exactly like this. With the data given, it is not possible to calculate max speeds for every configuration available in the market. To achieve this, I'd need to add a sketch pad to draw any picture
				Posted: Thu Nov 17, 2011 10:36 pm
				by snowfree52
				@fluppie00 : thank you.
@harry : should I put the max power at max RPM then ? does it affect the way the app records laptimes of anything else ?
				Posted: Thu Nov 17, 2011 10:48 pm
				Please check the documentation for more information on these settings:
http://www.gps-laptimer.de/User_Interface.html (search for 'OBD Information'). It is mainly used to calculate the current gear from speed and rpms.
