iPad Minii Mount
EvolutionX
iPad Minii Mount
Post by EvolutionX »
For those that have windscreens shaped like mine making it difficult to mount the ipad Mini out of the way of your view into corners and such, I just received this a few days ago and it works pretty well. My dash is the hard type but it isn't smooth. Has texture. This thing stuck like crazy. Actually took me a few min to get it to release but it didn't leave a mark. It's the first dash mount that I have had hold. The suction cup is made of some VERY sticky material that you can renew just by getting wet. I guess it allows the "material" to fill in the texture in the dash and make a tight suction.
I got it on amazon for about 27$ It's the iOttie Easy Smart Tap Dashboard Car Desk Mount Holder Cradle for iPad mini
Just tried it driving around the street and it never lost suction to the dash.
Just thought I would share. :D
iPad Minii Mount
Thanks for sharing! Do you use an external GPS? Any comparison for GPS accuracy for the position and one directly behind the windscreen?
EvolutionX
Re: iPad Minii Mount
I have the XGPS160 but didn't test that. I mount it pretty much in front of the mini but on the glass and as far toward as possible.
O.k. with an external GPS, it will be fine to place the iPad anywhere :-)
Kind of fits in this thread:
www.padbay.net
Really cool and safe place for iPad mini in car
EvolutionX
That is really cool but I wonder about the angle. Isn't it suppose to be 5 degree tilt and 25 degrees rotated towards driver for the accelerometer to work right?
EvolutionX wrote:That is really cool but I wonder about the angle. Isn't it suppose to be 5 degree tilt and 25 degrees rotated towards driver for the accelerometer to work right?
Yes, when using the acceleration presets. When adding a fixed mount (mostly unchanged position), you can calibrate LapTimer individually and store this calibration finally. More information is available on www.gps-laptimer.de following Documentation (Acceleration Handling).
At least one review on Amazon said that the sticky pad did leave a mark on their dash. That sort of thing might be temperature sensitive too. It might not stick at all when it's very cold and stick too well when it's hot.
