Page 1 of 3
				Mounting Dual Electronics XGPS160 SkyPro GPS
				Posted: Fri Dec 04, 2015 10:09 pm
				by EvolutionX
				I am going to order it soon. I am curious how it would mount? I can't see it sticking to the dash on the track plus I am not sure I want it stuck there permanently. I don't have a problem doing on the windshield though. Looking for ideas. Thank you
				Re: Mounting Dual Electronics XGPS160 SkyPro GPS
				Posted: Fri Dec 04, 2015 10:12 pm
				If both the dashboard and the rubber base coming with the XGPS are clean, you will hardly get it moving. I think you need to go beyond 1.5G... In case you need more, I'd suggest to tape the rubber base to the dashboard.
				Posted: Sat Dec 05, 2015 9:26 pm
				by gplracerx
				My dash is textured vinyl and the rubber mat never stayed in place.  If you've ever put something like ArmorAll on the vinyl, tape probably won't stick either.  I ended up using
Scotch Extreme fasteners glued to the dash and the back of the device removed from the rubber mat.  It's not pretty, but it works.   I think there's a black version that might be less obvious on a dark colored dash
				Posted: Sat Dec 05, 2015 11:03 pm
				by EvolutionX
				Thank you. I guess I will have to try and see.  BTW don't use Armorall on your car.  I own a Detaiing company and there are so many other products out there better for your car. Plus you don't want a shiny dash it just reflects the sun into your eyes.
Thanks again.
				Posted: Fri Dec 18, 2015 7:52 pm
				by EvolutionX
				I just got the dual. There is no way in heck it's staying on my dash. One quick turn and its sliding out the window. LOL I think I am going to stick one of the gopro sticky mounts to the bottom and get a suction mount and mount it to the windshield.
				Posted: Fri Dec 18, 2015 10:15 pm
				by gplracerx
				I see a number of people who use SoloStorm mount their Qstarz GPS mouse on the roof of the car with hook and loop fasteners.
				Posted: Tue Dec 22, 2015 8:19 pm
				by EvolutionX
				I went ahead and rigged the GPS holder using a cheapy Amazon gopro holder. I used the sticky gopro mount for the bottom of the Dual XGPS160. That's when the puzzle began. There are no pieces that fit together to get it mounted. All the gopro links are 2 "finger" on one side and 3 on the other. So I finally decided to snap off one of the 3 fingers on the size with the nut.
BTW does it matter if the unit is level? Will it work if it's right up against the A Pillar? or does it need to "see" to the side as well to pick up all the satellites?
And here is my masterpiece. LOL
				Posted: Tue Dec 22, 2015 8:44 pm
				by gplracerx
What you want is a clear view of the horizon in a full circle to get the maximum number of satellites.  So the ideal place for the antenna is the roof of the car.  That gives the antenna a good ground plane too, assuming a metal roof.  The advantage of the Dual is that it can use the Russian GLONASS satellites as well as the American ones.  That means you may still be able to get decent precision with a restricted view of the sky.  A dash mount, for example doesn't see to the rear very well, but it still works.
				Posted: Tue Dec 22, 2015 10:15 pm
				by EvolutionX
				The roof is aluminum. Will it still help to have it on the roof? If I'm going to roof mount it in going to get a real GoPro mount or another RAM mount.
				Posted: Tue Dec 22, 2015 10:16 pm
				Yes, it will be far superior compared to any in car mount.
