Qstarz BT-Q1000eX
Posted: Wed Nov 02, 2011 12:05 am
by gt350ed
I'm at my wits end. The manuals are terribly inadequate. This recorder SEEMS to operate and indicate a GPS signal. I then walk or ride a "course" to test it in QRAcing and attempt to "Read Logs". But I get a "GPS device connect fail" message as if the software is not seeing the recorder. What have I done wrong. I just received it via Amazon and if I cannot get it running, I'll be forced to send it back.
Any help would be appreciated.
Re: Qstarz BT-Q1000eX
Posted: Wed Nov 02, 2011 7:59 am
To make it work with LT you need to jailbreak your phone and install roqyBT4. The Qstarz is not compatible with LT out of the box. Please read more on this here:
http://www.gps-laptimer.de/Compatibility.html
Posted: Thu Mar 15, 2012 11:25 am
by popeysson
hello harry
i know this GPS is not on the supported device list
but if possible i'd like some hints on how to use it with LT
iphone 3GS, ios5.0.1
i got roqy 1.32, i'm able to connect to the GPS, so far so good
now, i'm wondering on how to use it with LT as it doesn't appear in the sensor list
i'm playing with the settings but without success so far
thanks
Posted: Thu Mar 15, 2012 1:51 pm
As the royqBT connected GPSes simply replace the internal chip, they appear to LapTimer as 'internal GPS' and are reported like that. To understand if the signal shown is from the internal GPS or your external device, you need to watch the values delivered. If for example you have set the device to 5Hz update rate, you should see this update rate in LapTimer's GPS View - instead of 1 Hz delivered by the real internal GPS.
Posted: Tue May 01, 2012 11:16 am
by Colonel_Klinck
Hi Harry. Used your Laptimer Pro (paid for
) for the first time at Snetteton yesterday. Worked ok but does need a better GPS than the iphone provides. Are there plans to make it work with a 10hz device like the Qstarz BT-Q1000eX??
Posted: Tue May 01, 2012 12:21 pm
Currently, there is no 10Hz GPS Apple certified. I expect this to change over time, but the best you can get now is 5Hz (see
www.gps-laptimer.de/Compatibility). The Qstarz can be connected using roqyBT4 / jailbreak - although I do not recommend to do this. As soon as devices get available, I adopt to them
