lost data
lost data
Harry, hlt crashed, said the db was corrupt, I answered 'yes' to fixing it and now all my laps, car, and id are gone. I don't have a backup of this weekend yet and don't want to lose this stuff. To complicate things I reentered car and track data and ran session with the new blank db.
Aaron
Aaron
Re: lost data
Oh yeah... Android, gran Prix, running on droid RAZR m, v4.4.2
Re: lost data
The general approach to restore your data (in case you do not have a recent .hlptrl export is available), is described in viewtopic.php?f=39&t=2626
The problem for LapTimer's Android implementation is Android does not allow access to the app's data area (named Documents in the FAQ). So as long as your device isn't rooted, this approach to restore data is blocked.
But the good news is most of your recordings will probably be available for a later restore at some time:
I have some solution to access Android automatic backups for v20 (LapTimer 2016 Spring release).
Please do not delete the app until this solution is becoming available, this would delete automatic backups too.
Re: lost data
So I can't get the old stuff back until the next version?Harry wrote:The general approach to restore your data (in case you do not have a recent .hlptrl export is available), is described in viewtopic.php?f=39&t=2626
Re: lost data
Rooting is not an issue. I'm assuming it's to get to the folder where the db is located?Harry wrote:Yes, except you root your device.
Re: lost data
Exactly. The structure in this folder is exactly the one described in the iOS specific link above.
Re: lost data
OK, assuming I don't blow it up during the root that's what I'll do. ThanksHarry wrote:Exactly. The structure in this folder is exactly the one described in the iOS specific link above.
Re: lost data
OK, root successful (what a pain rooting old phones) and I've found all the recovery directories, copying them to an sd card just to have another copy. I think I know what caused this - ever since a couple updates ago at the end of a session and I stop the HLT session, the device will stop recording on the gopro 3 but won't allow me to shut off the power to the camera. If I do, the camera powers back up no matter how many times I turn it off. The only way I can keep the camera off is to do a Force Stop on the app - still powers back up even if I "exit" of of it. Ideas?
