BT1A half the bandwidth if BTLE sensors on
Yesterday I noticed my BT1A was only showing 3-4 Hz instead of the usual 6-7 Hz. I looked for new options in the last release and tried the expert setting for the BTLE sensors and deactivated it. It did the trick and I'm back to my 6-7 Hz.
Re: BT1A half the bandwidth if BTLE sensors on
Yes, while BTLE discovery is active, bandwidth is reduced. This is the reason LapTimer v19.0.22 (or 19.0.23? Need to check) turns off any discovery of sensors after 15 minutes.
