Autocross detection corridor setting
A forty meter corridor, as implemented in the latest version, can be half the width of a small parking lot. It would not be difficult for a course to cross a corridor that wide more than once. I know that the width can be changed in Expert Settings, but it would be nice for the autocross course setup wizard to do that automatically and not to default to wide setting if a direction is specified for the trigger. Even with a narrower setting, I had to move the finish line away from the actual location at my last event so it didn't trip early.
Re: Autocross detection corridor setting
Thanks for the feedback. That's actually a difficult one because the corridor is a global setting and cannot be specified by trigger or by track. Next version is planed to have driving direction support built into the AX assistant, maybe I can add a warning or option to toggle to the lower setting here...
jwmelvin
Post by jwmelvin »
An option to toggle the setting would be fantastic. And thank you for building in the direction support!
