laptimer settings for 2012 cayman s with pdk
ottoburgess
Post by ottoburgess »
hello all
can someone send me the correct laptimer car settings for a 987.2 cayman s with pdk?
specifically i am looking for ft-lb@rpm and hp@rpm with the 3.4l engine with pdk
oh, also gas tank size, i think it is 14gal
thanks
otto
Re: laptimer settings for 2012 cayman s with pdk
Have you checked the Cayman's manual? Porsche usually has all this information listed.
ottoburgess
Harry wrote:Have you checked the Cayman's manual? Porsche usually has all this information listed.
and there it is, page 222
still, when i can, it should be put on a dyno for car specific numbers
would this not help laptimer be more accurate?
Please keep in mind what the power, torque, and rpm values are used for. They are used to show you a rpm dash in video showing rev section to stay in. They support you to drive at high enough rev number (green) and to display a shift flash when too high. All provided you have an OBD II adapter connected. You will not recognize the difference In case values are slightly off.
ottoburgess
harry,
by the way, not all info is in there
lacking gear ratios and final drive ratio for the pdk to start
found this on planet-9
Here are the ratios from Top Speed for the 987.2S
Manual Pdk
1St 3.67 3.91
2Nd 2.05 2.29
3Rd 1.41 1.65
4Th 1.13 1.30
5Th 0.97 1.08
6Th 0.84 0.88
7Th – 0.62
Reverse 3.33 3.55
Final Drive Ratio: 3.88 3.25
but now i cannot seem to add them to laptimer
tap and hold is not working for me, i see no '+ gear'
i am using a note2 android
otto
Try the action menu (three dots in top right). It includes a Add Gear item.
ottoburgess
Harry wrote:Try the action menu (three dots in top right). It includes a Add Gear item.
got it, thanks
