non obdII data logging
Posted: Mon Aug 03, 2015 4:36 am
by Bryant
Great product!
i would like to be able to incorporate my engine data like the obd II interfaces do. my car is carbureted but may switch to efi later. i have the innovate data loggers ( http://www.innovatemotorsports.com/products/ssi_4.php ) they work well with a computer. is there any way to to get this type of datalogging to work with lap timer?
Posted: Mon Aug 03, 2015 9:14 am
The only out of the box solution to retrieve engine data for non OBD cars is Autosport Lab's RaceCapturePro / MK2. Adding a BT adapter allows it to connect it to LapTimer GP In Android. For iOS, a WiFi option is missing, please contact ASL and ask them for support in case you use an iPhone.
The ASL RCP is a great solution by the way, and very flexible. Especially in case you have done some wiring for the innovate box, it should be easy to switch.
Re: non obdII data logging
Posted: Tue Aug 11, 2015 7:48 pm
by jexeffectz
I have a 1992 Mazda Miata with OBDI. I've already purchased a Megasquirt Standalone ECU for tuning purposes. But I was wondering if there was a way to link the data to the laptimer using this: http://www.tunerstudio.com/index.php/cablesandbluetooth
I imagine, it might be easier for the connection to be better with android since the adapter is android ready, however, would it be possible to do the same with apple?
Posted: Fri Aug 14, 2015 8:05 am
Android will be able to make a connection using such a bridge, iOS not as it requires BT clients using the SPP service to be certified. On top of this, a MS protocol implementation is missing in LapTimer so far, so no luck for both platforms currently...
