HLT crashes
shaq0853
HLT crashes
Post by shaq0853 »
Hi Harry
I'm using HLT v19..8 (64) on my iPhone6 plus (iOS 8.4 12H143)
Got crash when trying to access all sensor list, or trying to create new course.
Please help cause next trackday is on 1st Aug, and still have no track data.
Re: HLT crashes
Which language setting do you use? I just fixed crashes in the named views which were due to some handling issues with Japanese symbols...
shaq0853
Re: HLT crashes
Post by shaq0853 »
Harry you are right, was using Chinese traditional, after switch to English, HLT become stable.
Will keep testing, thanks.
BTW, recorded some videos but speed wasn't correct, what is the possible reason?
Thanks again.
Following is the videos
http://v.youku.com/v_show/id_XMTI3MjM4OTk3Ng==.html
http://v.youku.com/v_show/id_XMTI4MzE5ODgxNg==.html
HLT crashes
GPS speed will always show a value below that shown on your dash (which is always too high). GPS is more precise than wheel speed measurements when going at constant speed, but it is lagging and will miss short time peaks. There is not a lot one can do about this, 10 or 20 Hz GPSes are only a little better and share the same principle problem.
