HLT and GoPro 4 Silver - HLT Changes Resolution
Posted: Fri Jun 26, 2015 4:18 am
I've used HLT for quite a while now but never with video. I just picked up a GoPro 4 Silver and had no problem getting the camera to connect with the HLT app (Android, Galaxy S6). What I am noticing is that when the camera connects with HLT, the settings on the camera change from 1080P superview and wide angle to 1080P and medium angle. I can change the settings back to 1080/wide angle on the came after I'm connected with HLT, but I'm curious as to why the settings change when I first connect with the app?
As a side note, I tried to change the internal cam resolution setting in the HLT app which did nothing to stop the camera settings from changing. I actually noted that anytime I changed the internal cam resolution setting while the camera was connected, it would revert the GoPro back to the 1080P and medium setting. Thanks for the help.
-Justin
-Justin
