can't find the data file to transfer it to PC
ralt racer
Post by ralt racer »
Hi Harry, this forum is great BTW
I've been looking through the files with Ibrowse to try to find the data file so that I can analyse it on my pc. Ideally I don't want to send it via email or dropbox as if I want to check it over at the track and haven't got access to WIFI I cannot get the file, can you tell me where it is located and if I can convert it and save it without emailing it?
Cheers
Re: can't find the data file to transfer it to PC
iBrowse and iFunbox are blocked since one of the recent iOS8 releases. The workaround added is iTunes File Sharing - which allows access to LapTimer's Documents folder. Exports however will be stored in a temp folder (in parallel to Documents) and I doubt it is accessible through iTunes File Sharing.
