configurable shift gear beep
KrisS
Post by KrisS »
Unless I missed it and this feature is already in place
It would be nice that while measuring time or video recording there would be a configurable shift beep that tells driver without looking at the screen that he should change the gear ?
Ideally:
- ability to choose beep sound type (defined list or downloaded from sound file)
- ability to define type of beep - frequency, length of the beep, loudenss, etc
Re: configurable shift gear beep
I've put this on the list... As I would like to keep it simple, I will go for one sound only. My suggestion is a continuous beep in sync with the flash?
KrisS
Post by KrisS »
The solution I saw (based on HW) is that it either it gives single loud beep on set RPM (or more advanced it is that it starts beeping just before the setup revs then frequency increases and beep becomes constant beep when you are in "red" area). Sound seems better for me as I'm concentrating on the driving not on the screen. Of course you should be able to switch on/off this feature
ben
Post by ben »
I like the idea. Especially if your car has AUX input for audio. :)
