Can I modify existing Track Set?
Posted: Tue May 19, 2015 3:40 pm
by mbulls
We run ChumpCar in the States. We are running a 14 Hour event on May 24th, 2015 at Daytona International Speedway. Late notice I know. Normally we run the Rolex Course which is an existing Track Set. They sent us our information packet last week and because they are working on turns 1 and 2 for Safer barriers, the Track wants us to run a modified course. I attached a map. Is it possible to take the existing Track Set and modify the POI for Turns 5,6,7 and 8? If so, please let me know how to do this.
I can submit a Google Map as a KML or KMZ if needed. Is it possible to get any help in the next day or so.
Thanks in advance,
Michael
Re: Can I modify existing Track Set?
Posted: Tue May 19, 2015 5:21 pm
Monika will check the changed configuration. Due to the limited changes, you will actually be able to use the existing track set. The problem is you can't compare it to regular laps - it is shorter and faster.
Posted: Tue May 19, 2015 8:47 pm
by gplracerx
Configuring Start/Finish must be tricky, as it needs to trip when you go through pit lane as well as when you're on the course.
Posted: Wed May 20, 2015 11:53 am
by Monika
Hi, I will add a separate configuration for this modified track version.
Usually laps through pit lane are not taken into account for time recording, only regular laps to make laps comparable.
Do I understand correct, that the green line is the correct circuit used ?
The new configuration is available for download!
Please check it out via 'add-ons', 'Update' list via the button at the right top,
search for the track e.g. via 'Daytona Mid' and download the track.
- Monika
Posted: Wed May 20, 2015 1:18 pm
by mbulls
Monika, that is correct, the Green line is the correct Circuit. ChumpCar used the yellow just to indicate the Pit Road. Thanks so much for creating this track and adding it. I just went and downloaded it. You guys are the best. That is why all of us continue to support Laptimer. You, Harry and the team are always responsive to our needs.
Thanks again for the quick service:-)
Michael
