Problem with session overlay and Gopro master footage.
Posted: Sun Apr 12, 2015 4:43 pm
I am having a problem overlaying obd data to several sessions recorded yesterday at Goodwood,
I have a gopro video as the master and the iphone video as the 2nd video, using gopoint BT1, it works fine to overlay a single lap but when trying to overlay the sessions the odb and gps/g sensors data freezes as I cross the start finish line, (this is right at exit of the pits or at the end of the first warmup lap)
I have set the obd settings to Sequential requests and auto exclude PID's to on, Harrys lap timer often says slow update rate from the sensor) car is an 05 Impreza STI the data update rate has always been a little lethargic but I have not had these freezing odb/gps/g-sensor problems before at Spa or the ring etc. overlaying with the Iphone footage does not cause the issue it seems..
oddly the speed and corner names still pop up in the top left corner.
I have no other applications running on the iphone (6 64gb) and have enough free space.
Any advice or help you could offer would be greatly appreciated
