Hello from Dubai Harry,
Love your app and thanks so much for your efforts.
I have the Grand Prix Edition of your app and the version is the v18.3.9
My issue is that whenever i am out on track it does a great job of timing all my laps.
But for some reason only my fastest time of the day is not featured in the Hall of fame. It will post the second fastest time to the Hall of Fame.
this has happens on all my trackways. i have internet connection all the time when on track. always chooses not to add my best lap to the Hall of fame
On all laps there is an option as you know to tap on called "Hall of Fame" to upload the Lap. but my fastest time of the day always does not have that option available to tap on.
would appreciate your help
the circuits i drive on are Dubai Autodrome GP circuit and Yas marina GP circuit
thanks in advance for any help
Problems with only fastest Lap uploading to Hall of Fame
Hi, the only reason I can think of (without looking into the code) is you have some tag set for the lap that makes LapTimer consider it not your own lap. If for example you have "Harry" set, it will not be submitted. Please check the tags row in the lap's details.
Re: Problems with only fastest Lap uploading to Hall of Fame
Thank Harry.
i checked and the Tag in all fastest laps is mentioned "ME" and not Harry.
attached is a screenshot of such one of my fastest laps that has not been sent to the hall of fame
any other suggestions?
- Lap.zip
- (254.9 KiB) Downloaded 87 times
I checked the server and there are indeed no submissions for and '911 GT3' for one of the Dubai GP tracks (1141 to 1144). You may send your 3 digit driver name so I can check it that direction in addition. I rechecked the conditions necessary to get the Hall of Fame button for an individual lap. They are as follows:
Finally, to submit lap times, you need to enable lap publishing. You find this setting in LapTimer's Settings right in to top: make sure "Publish" is set to "Lapping" - which is the default setting.
- the lap needs to have been performed by yourself
- the lap needs to be a lap recorded automatically - i.e. using triggers (no manual timing)
- the track the lap belongs to needs to be in "certified" state
