Boost Data Log for Turbo Cars Question
Posted: Tue Feb 17, 2015 10:58 pm
by Blue03Si
Hi! I just recently became a LapTimer Petrolhead edition for android user. I used it this last weekend to data log an autocross in my 2015 Subaru STI via OBDLIMK MX via Bluetooth. I was going through my data-log from the runs and was trying to figure out how to convert the data from the MAP sensor to PSI boost/vacuum and am completely stumped. I Googled a bit trying to figure it out but nothing seemed to correlate. Am I missing something? Is there a way to log turbo boost/vacuum in any other format than the default MAP numbers?
Re: Boost Data Log for Turbo Cars Question
Posted: Thu Feb 19, 2015 10:16 am
MAP is coming as a one byte value between 0 and 255 corresponding to 0 to 255 kPa absolute pressure. Atmospheric pressure is around 100 kPa (depends on weather conditions and height), so the relative pressures range is between - 100 kPa and + 155 kPa. To convert to psi, use 1 pound per square inch =
6.89475729 kilopascals
Posted: Thu Feb 19, 2015 10:17 am
Need to check, but LapTimer probably uses Bar for MAP export with 1 Bar = 100 kPa
Posted: Thu Feb 19, 2015 5:37 pm
by Blue03Si
Harry wrote:Need to check, but LapTimer probably uses Bar for MAP export with 1 Bar = 100 kPa
Thanks Harry! I really appreciate you taking the time to answer me. It looks like you're right, its in Bar. The part I was missing was to subtract out 1 atmosphere in my conversion. If I multiply it by 14.5 then subtract out 14.5 it looks more like what I expect for my RPM and throttle position.
Eg.
MAP - 1.74; Boost - 10.73
MAP - 1.99; Boost - 14.35
MAP - 2.22; Boost - 17.69
If I'm missing something let me know, but I think it got it.
Thanks again!
Posted: Thu Feb 19, 2015 7:45 pm
Yes, that's sound.
