Omex ECU integration
nariman1977
Post by nariman1977 »
Hi
Is there anyway to connect to an Omex ECU to get the data from the ECU for the sensors?
I have replaced the ECU in my car and this app looks promising if I can get the data from the Omex.
Naz
Re: Omex ECU integration
As long as the ECU is integrated with the OBD II port, you can use a compatible OBD II adapter (check home page - www.gps-laptimer.de). Custom PIDs are not supported currently.
nariman1977
Hi
No, the ECU is not integrated with the OBD port. It has a dedicated wiring loom which is separate to the old ECU loom.
It has a 9pin serial port which outputs the data to a windows program called 'Dash2'.
http://omextechnology.co.uk/page75.html
